Speedfusion Connect - what goes over tunnel?
I use SpeedFusion to a server in a Vultr cloud. It works for many things, but many web sites block connections from Vultr data center IP addresses. That’s life.
Speedfusion Connect might be a better option for some of our use case. We’re using a MAX BR2 Pro, with either 2 links (Verizon and T-Mobile) active, or 3 (add in Starlink). But what isn’t clear is how to get traffic to go out over SF Connect. I enabled a tunnel to New York. That makes sense, and it’s up. But there’s then configuration for applications, and that makes no sense. Is SF Connect only going to work with selected applications, or can everything going out to the Internet from the BR2 Pro go out over SF Connect?
Despite reselling Peplink routers for many years, I’ve really never dug into SF Connect, and still do not understand how to configure it to be an endpoint for combining all traffic from a router pushed out over multiple upstream interfaces.
Pretty straightforward, but you need to enable SFC and, once saved/applied, set your outbound policy rules accordingly.
Could you, or someone, expand upon the “set your outbound policy rules accordingly” part of that? A full how-to that has the setup of SFC in addition to ALL OTHER settings to make it work is what I think is missing from documentation.
I could greatly benefit from that “how to” also. Thank you.
There are tons of videos showing this:
Thanks for the video links. There is STILL a need for a print/text/pictures HOWTO. Documentation still matters. Videos are not documentation.
So the first video you posted shows how to turn on Speed Fusion Cloud (yes, an extremely out of date video given branding). That video then says the next video will say how to set up SpeedFusion rules to go with it. But the next video you have isn’t from that person, and doesn’t follow.
THIS is exactly my point. I am looking for a HOWTO that gives, start-to-finish, how to successfully set up SFC to get traffic out through SFC to any destination on the Internet. Not disjoint, go track down stuff, but a single, concise setup guide. Clearly Peplink staff have some clue how to do this, and hopefully Peplink has some technical documentation staff.
And for those wondering what I’m trying to accomplish here: When I use SpeedFusion VPN using 3 or 4 uplinks and target a FusionHub, I am able to set up FEC, Smoothing, and load balancing to establish a highly reliable link for real-time video streaming data for events. The underlying question is whether SpeedFusion Connect actually has any relationship to SpeedFusion VPN, including the ability to do the same thing, but through Peplink’s cloud service endpoints. In my experiments so far, regardless of outbound policy setup, the IP address my traffic originates from is one of the active connections on my router, NOT that of a VPN endpoint at Peplink.
Both use SpeedFusion to achieve the packet level bonding, but the hosted service has limitations around what you can configure, particulalry for features like FEC, smoothing and so on, particularly the low level settings that often need to be tweaked to get the bonding to perform at its best.
Frankly, for your application I would not use SFC and istead host your own FusionHub somewhere - that could be a public cloud provider, or somewhere you own and control and you get full control over the behaviour of the hub.
SFC tunnels can be used in outbound policy rules just like a tunnel to another Peplink or a FusionHub, could you perhaps post a screenshot of your outbound policies, along with some details of your internal LANs / important IPs and how you are expecting them to be steered into the tunnel.
In essence though you would make a rule that:
  1. Matches your traffic, probably by source IP or subnet - say the IP of your encoder.
  2. Applies some traffic steering rule to that to send it into the tunnel
  3. Place the rule appropriately so that it takes effect before others.
It is quite easy to achieve this kind of traffic steering, as long as the rules are correctly matching the traffic in some way, and are correctly ordered - OBP rules are processed top to bottom, the first rule that matches for a given traffic flow will be applied, it could be as simple as you have the rules correctly set but the ordering might be causing them to not behave as you expect.
I would also remove any configuration you have under the SFC settings for directing traffic into SFC for now.
If you are using InControl2 to configure OBP there are a few options avalable for SaaS services that you do not get directly on the unit, but the core concept is the same.
Oh, and this:
Likely won’t change much, SFC is hosted in a variety of public cloud providers, they all face the same issues at some point. The only way really around this is hosting the hub endpoint somewhere you know the IPs are properly geolocated and not on a list as “datacentre” or the likes.
I would agree that Peplinks docs are a little disjointed at times, and I am also no fan of videos versus proper written documentation, the linked sections below do cover SFC and OBP to most extents, the linking of the two featuers together is probably where the SFC section needs a bit more but for most of the target audience using SFC the “route by” features probably get the job done.
https://manual.peplink.com/peplink-max-user-manual/#1571
https://manual.peplink.com/peplink-max-user-manual/#1721
Thanks. One issue I realized is the need, once SFC is enabled, to click on the name of the connection to get the parameters. That’s one of the items that the videos seemed to miss. I.e. HOW to get to the SpeedFusion parameters for SFC.
As an experiment, I’ve now got SFC enabled with three links. I try whatismyip.com, and get one of those links, and not the IP address of some Peplink data center location that’s providing the relay. I did set up an outbound policy to route everything, though with SFC enabled without further policy, it would make sense for everything to go out over SFC anyway, especially if this function is going to share a name with SpeedFusion VPN.
As to your comment about best approach for my application, I agree. And I do use a FusionHub in most cases. But there’s an issue with that. Having the hub in a cloud service results in much traffic blocking if trying to go to many web sites. I host a lot of stuff in cloud services, and I too block a lot of other clouds and for good reason: cloud vps services are used relentlessly to attack other services, spew spam, etc., thus they must be blocked to protect one’s own web resources. My hope in getting SFC working was to find a way to use SpeedFusion for its ability to blend uplinks, but without the liability of running into blocks.
