I’ve purchased a SpeedFusion Connect Plan for my MAX Transit Pro E.
I can see it available under my SFC Management page, and under my Feature Activation tab in InControl.
How do I go about getting them sims configured to use the connect plan?
I’ve looked for documentation. I couldn’t find any.
Doesnt Speedfusion connect use eSim?
I believe it does. I am not unsure how to actually get it connected on the hardware.
@Robert_Beeman, you may refer to the FAQ here. If you are not using 8.2.0s011, please upgrade it to the firmware below:
https://download.peplink.com/firmware/plb1/fw-b1_210hw4_310hw4_br1ent_transit_m700hw3_hd2mini_hd4-8.2.0s011-build5320.bin
Then select the option below from cellular WAN to enjoy the SpeedFusion Connect!
Question: can the eSim only be used for SpeedFusion connect or can it be used with other carriers?
The esim can only be used for speedfusion connect.
