SpeedFusion Connect App to FusionHub
Just saw the announcement for the SpeedFusion Connect App. Straightforward to get working to one of the hosted servers.
But question: Can I connect the app to my own FusionHub?
Only if you enable SFC Relay mode - so only indirectly, but you will be able to exit your Fusion Hub node.
It would be ideal to allow a direct connection to a FusionHub or router in addition to SFC.
Would also like to verify that a SFC plan is not needed here, correct? - After a bit more reading, a SFC plan is not required.
I was super excited when I got the email about this new app, but the lack of ability to connect it to FusionHub prevents the app from having any use to us right now.
Hopefully that is rectified soon.
I’d like to see this in the form of being able to simply have a user install the app, then give them an assigned user key (no peplink account) to enter that we can generate from a speedfusion profile in IC2. Then that links it up and we can have a little bit of provisioning and management for those connected users from IC2.
I can only support this question. It would be very good to have the possibility to connect a mobile client to the own Fusionhub and integrate in the SD-WAN network to access internal resources. Above OpenVPN is has the bounding features and the OSPF routing updates, which is quite important and a Peplink USP.
