SpeedFusion Connect 400 Mbps Metered Plans
Hi All,
I am a Peplink reseller as well as maintaining a large rental inventory of Peplink Products. I work primarily in the event / film & television field. I would like the option to purchase Speedfusion Connect metered plans that will do 400 Mbps. Peplink devices used by my clients, both rental and sales, are used sporadically so a metered plan is the only viable option. Placing my rental inventory and client devices in an unlimited plan, when they are used infrequently would be quite expensive.
As cloud hosting is generally billed by the compute time and amount of data transferred, the cost would vary little based on 200 or 400 Mbps transfer rates.
Why not build FusionHub VMs for the client yourself and bill the client for the usage however you want?
Actually… reach out if you want and maybe I can help you build this.
Thanks for your reply. I do have a Fusion Hub instance in AWS but that is only in one location (California North). My clientele is scattered throughout the US, so the multi-location component of Speed Fusion Connect is quite useful, it’s just that 200 Mbps is not fast enough in some cases. And of course, the Fusion Hub licenses are not free either.
FusionHub can be very economical depending on how you use it, and whether the other device has Primecare/Essentialcare.
