SpeedFusion Cloud showing Cloudflare WARP instead of Cloudflare – normal?
Hi everyone,
I’m using SpeedFusion Cloud on my Peplink BR2 Pro and noticed something unusual.
Before, when connected to SpeedFusion Cloud, speed tests showed Cloudflare as the provider. Recently, it started showing Cloudflare WARP, even though I don’t have any WARP app installed on my phone or computer.
My questions:
Is this normal behavior with SpeedFusion Cloud?
Did something change in the backend (Cloudflare integration)?
Does this impact performance, latency, or routing?
Is there a way to control or avoid this?
I tested with different WANs (Starlink and 5G) and multiple devices, same result.
The connection works, but I want to understand what changed.
Thanks!
