Speedfusion Cloud doesn’t configure the same way that a Fusionhub instance does. If you select “Choose Cloud Location” then select the link for the Speedfusion Cloud that you’ve established, you’ll get the configuration screen. There is NO configuration except for this and it does not show up anywhere else in the Peplink interface. If you want to specify the Traffic Distribution Mode for the Speedfusion Cloud tunnel, you have to go into the support page and enable it (you’ll see it there if you’ve established a tunnel). Then it will show up as an option in the Speedfusion Cloud configuration page mentioned above. You can now specify a bonding method.
To get to the support page, change the bit in the URL that starts with “index.cgi…” with “support.cgi” and hit return.
You will see the Speedfusion Cloud on your Dashboard but there’s no links or anything here. You’ll also have all of the same Status capability on the Status page if you want to diagnose anything.
