Hi there,
New to Peplinks, loving it so far. I have a Max Transit Duo which has listed in the spec’s as 100mpbs of Speed Fusion Throughput with no Encryption - the unit has a SFC subscription and it lists max as 200mbps. Is the unit still limited to 100mbps? Guessing thats a hardware limitation?
I’m assuming also if I had say 5 SFC profiles running it would be a combined limit of 100 between all of them not 100 each?
And finally is the throughput 100mbps up and 100mbps down? or 100mbps shared?
Thank you!
