Hi, I have a setup like in the image. But the Speedfusion connection isn’t connecting. Ports are default, settings are according to manual. NAT is on on both sides, but this shouldn’t effect the connection, just the later routing if at all. Can anyone help and suggest a fix?
why are you using drop in mode? Disable drop in mode does the tunnel build then?
I want to avoid a double NAT
