I have 1gb fiber, peplink is slowing down my connection while pegging the CPU on Ethernet via cable.
Is there a solution to the speed slowdown introduced by Peplink? Should I just go to a different vendor?
I’ve seen a a balance one do 600Mbps + so something else is going on here.
In your WAN settings set everything in physical interface settings to auto.
Disable any other/additional WANs when you do the speedtest. Also use fast.com for a 2nd measurement.
I assume you are testing speeds with a wired device (ie a laptop connected via Ethernet)?
[edit just sen you are testing with both ethernet and wifi. For tests only use Ethernet for now).
