Speed fusion relay
hi,
I tried to get a speed fusion relay here in austria but it looks like it is out of stock everywhere … now considering buying a peplink max 5g pro for my van and put my old peplink max bro mini instead to my home network to “mimic” a sf relay
  • is this possible to get the same effect (seamless sf relay connectivity for eg streaming services)
    any advice appreciated
    cheerz
Hi Gerold,
you can use the SpeedFusionCloud to get an uninteruptable stream.
If you need more details, feel free to call me.
Dennis Hofheinz
Zentrale: +49 89 9542965 0
I know,
already using a speefusion hub on an AWS nano instance … works fine BUT quite expensive monthly AWS cost … that’s the reason I would like to switch to own hardware :wink:
