Hi everyone having problems trying to bond 2 SIM cards both have similar speed and latency but anytime I do a test I get the same speed as one card. I have made sure to route all my traffic through the vpn tunnel. Saw some comments about mut being sent wrong. Has anyone has similar problems. I am using a max transit dueo. Man thanks
Both set to Priority 1?
Hi yea both sims are set to 1 priority and have been though all the other steps. Opened a ticket a few days ago but no reply as of yet.
Ah ok. I presume FEC and WAN smoothing are both off? WAN smoothing will eat up 50% of your bandwidth as it uses both WANS equally.
FEC on low will use about 13% and high I believe 33%.
Yes both are off didn’t realise fee was so much but very handy to know
Just a sanity check: You have installed a license for SpeedFusion for the transit duo (MAX-TST-DUO-LC-SF)? Without that your VPN connection is using only one of the cellular radios for the SF connection.
Cheers,
Z
Is this transit the primecare edition or the regular one?
Can you post some pictures of your vpn settings?
