Speed Fusion Alliance Fusion Hub Licenses
I am at the max number of Peer Licenses and cannot add a new BR1 mini with PrimeCare to a VPN in InControl2. The FusionHub I am trying to setup the VPN on is under the SpeedFusion Alliance FusionHub License section under Warranty & Licenses tab In IC2.
I was under the impression that PrimeCare did not count against this total. Is this incorrect and is there a way to add more Peer Licenses?
I am subscribed to FusionHub on AWS if that makes any difference.
You should be able to create the profile anyway and when it will establish the tunnel it will not be deducted from the number of available peers.
If you need more peers, you have to be a pack of token that will be added to your organization and then you can expand the amount assigned to that hub.
