Hi I’ve been happily using a Pepwave Surf Soho router with an ARRIS SB6183 modem for 2 year in my non-profit. Part of that involves Veterans PTSD support and now raising PTSD pups. SPECTRUM did something to break the Soho WAN connection. Also the 7.0 firmware fails to load with a “bad Image”, but passes the verification ph
ase
the arris works fine on a lan connection to my macpro.
please help me/us
rev tom
We currently have two images for the SOHO. Please check the Status tab for the hardware revision. When you go to the firmware download page please make sure that you are downloading the firmware hardware image.
Zach,
thank you for responding
did notice that after my 1st cup of Coast Guard sludge
I’m at HW version 1 & did upgrade to 6.3.5 successfully
STILL not connecting WAN wise
tomj & Foster
there is a problem with my Surf Soho HW1 and the 6.350 upgrade with the WAN Page inputs
picture file 1 shows what the top of the WAN config page looks like
picture file 2 shows what my current Pepware WAN config page is. THEY ARE DIFFERENT I can't input the modem or gateway ip addresses
Sorry, actually, the latest firmware revision supported by the Surf Soho (Hardware Revision 1) is 6.3.5
The Surf Soho MK3 (HW 1) can take the newer 7.x firmware.
