I need to connect to a Wi-Fi WAN which uses special characters (double/single quotes) in its Shared Key. The peplink Pepwave MAX Transit (Firmware 8.4.1 build 5629) presents the error message:
WPA Shared Key must not contain the characters " and '.
This makes it impossible to connect to this Wi-Fi WAN. This is a limitation as other devices accept these special characters as valid.
Thank you for submitting the request. The Engineering team will review the feasibility.
Just to clarify the “Single Quote” is supported.
Only the “Double Quote” and the “Grave Accent” is not supported.
The Engineering team will study the feasibility for the double quote request ^^
The Engineering team able to create a special firmware to support the special character “double quote” for the WiFi connection share key.
Firmware 8.4.1s166 (Balance One/B210HW4/B310HW4/Transit/MAX700HW3/HD2 Mini/HD4:
https://download.peplink.com/firmware/plb1/fw-b1_210hw4_310hw4_br1ent_transit_m700hw3_hd2mini_hd4-8.4.1s166-build5668.bin
Tentatively the Engineering team will will try to include the improvement for the coming 8.5.0 firmware.
The double quote was the problem in my case
This was added to 8.5 b3
