Hi!
Is there any possiblity to use STP/RSTP on Balance devices?
It would be good to be able to connect the router to two switches which are interconnected.
Thank you
KPS
Hi!
Thank you
KPS
No need to worry about the STP/RSTP feature for Balance device. You can treat the LAN1 & LAN2 port as bridge interfaces. The BPDU packet will just forwarded to the second port. The switch should ports enable with STP will block the port.
