I’d like to add my voice to this set of feature requests. My decision to invest in Peplink routers and access points was based primarily on a desire to create a more secure network with VLAN isolation and control via internal firewalls. So far this has been achievable – except in the case of Sonos.
Please consider adding such a feature to a future firmware release. Many thanks.
Peplink Team,
I have multipe partners pulling their hair out because of this SONOs issue in marine installs.
Please can you make this happen? I have deployments where we can test it.
Hi Eddy. I bought a brand new SONOS One today to set up a lab. Would you believe - It works perfectly well across VLANs. I will now check to see what models of SONOS speakers are in use where inter VLAN control is not working.
@MartinLangmaid, would you able to share the model & generation for your SONOS One device ? It’s good that all know that model is working fine across VLANs.
I had it on a dedicated VLAN (tried it connected via both WIFI and Ethernet), and then ran the SONOS app on my phone connected to the Peplink via WIFI.
I setup two WIFI SSIDs one on untagged lan and one on the SONOS VLAN and tried hard to get the app to stop working but couldn’t no matter which LAN segment I was connected to.
@MartinLangmaid: Would you mind to share the VLAN config you made (I assume Sonos One is connected to a tagged VLAN) and maybe the sharing / transfer settings between VLAN and the untagged LAN (I assume the Cell Phone with Controller app to be connected to)?
Especially settings like Network → Inter VLAN-Routing (active) and AP WIFI Layer2-Isolation (active) and Guest Protect → Block all Private IP (active) would be of interest for me (values in brackets are my settings). Or maybe any Firewall / Transfer rules set? E.g. I activated network → bonjour service forwarding from VLAN to untagged LAN.
So at least with the abovementioned settings I made it, that my Apple Cell Phone found a Sonos One Gen. 2 and could stream to it via Airplay2 using the standard iOS features. However not with the Sonos S2 app, unfortunately. No idea what to do to get Multicast directed…
