When the bandwidth allowance limit was added at our request in a custom 8.0 build, it included reporting on those new fields in the API calls.
A section called bandwidthAllowanceMonitor was added to the sims array, and included monthly allowance and action.
These fields are missing in the 8.01 release.
We need to get this re-added ASAP so that our tracking system can watch for people approaching their limit.
I was referencing the normal incontrol API including the allowance fields in the “sims” object
I have checked with engineering team. We do not have the SIM/bandwidth limit function in IC2 API. Can you specify which API you called and how you call it?
Thanks.
sorry. i found it. it was in the direct device api and the issue is that you changed the format from cellular->gobi->sims to cellular->cellular->sims
so this can be closed but i do request that release notes include changes to all apis
