1- Is there any other optional more powerful antenna for AP-One like 8 db or more ?
We can provide you an optional 9dBi indoor antenna if you want to further increase the coverage.
2- Is it possible to attach the outdoor fiberglass antenna to AP-One ?
You will have to find a RP-SMA to N-Type converting pigtail cable for the outdoor antenna.
3- What’s the maximum number of clients acceptable on AP-One ?
Depends on what throughput you are targeting. Usually we suggest a maximum of 20 clients for a good usage experience.
4- What’s the maximum indoor / outdoor coverage of AP-One ?
Depending on the environment, throughput requirement, and client device capacity, there is no single answer to AP coverage. We can help you estimate the coverage case-by-case when you contact our team.
5- Is there any receiver family product in the way with standard 802.11n (HT40) ?
We have plans to release receiver family product with 802.11n in HT20/40.
6- Is AP-One access point dual band or single band ?
It’s a single band, single stream 802.11n at 2.4Ghz.
7- Does AP-Ones work with other manufacturers PoE or the PoE should be Pepwave also ?
The AP One will work with standard 802.3af PoE from other manufacturers.
8- Is AP-One access points 400mW or 500mW ?
Under FCC regulation, the AP One is capable of 500mW across all channel. Should you choose to omit the country restriction, the AP One can provide a peak power of 33dBi.
9- Is AP-One made by Taiwan or China ?
The AP One is made in Taiwan.
10- Does Peplink Wireless Controller capability support Office-Points or only AP-Ones are supported ?
The first release of Peplink WLAN Controller, using firmware 5.3, will only support Pepwave AP One.
11- Is it possible to have the Incontrol functionality on Peplink Wireless Controller ?
This is currently not supported.
12- How many VLANs are supported by AP-One ?
There is 4 Wireless Network (SSID) per AP One. Each one can be assigned to one specific VLAN.
13- Is there any other access point solution on the roadmap with USB Storage capability ?
Currently, we do not have plan to support USB Storage devices.
