Some issue with pep 710 please help
hi i run a peplink balance 710 H/W version 3 as a main router on my wisp network.i have a customer is tryng to play this game (https://www.playbattlegrounds.com/main.pu) but if press play take an error. i make inbound rules and outbound rules, nat mapping with a non used buplic ip from enything else and the issue is still here… i disable the firewall and i make rules to accept everything on the customer ip but nothing. the problem i thing is something with peplink becuse i connect the pc of a customer directly to my main isp modem and is work ok…
Current firmware version: 7.0.2
If there are multiple WANs this may require an outbound policy rule to keep that user on a single WAN link. MTU size on the WAN interface is another thing to check.
yes i have 3 wan…but i make outbound rule, nothing change ! and mtu size is auto on all wan, i try totay to change it and i tell you… something else;
Please open a support ticket and allow support team to check on this.
https://contact.peplink.com/secure/create-support-ticket.html
