does somebody know any option to get connected to a PepVPN without a router. My client has some external coworkers who needs sometimes VPN access. Is there any Windows 10 client being able to to get connected to a PepVPN Hub?
SpeedFusion is not needed of course. the staff needs normal network connections only.
Any idea?
Thank you.
Best regards
Gr. I.
I have found this feature under “Remote User Access Settings” …
If I download the OpenVPN Config, only the internal IP of the WAN Interface is used. I had to replace with the real external IP. Also the port forwarding from modem is necessary, which is normal, of course.
Where is the “Remote User Access Settings”?
For the balance routers the information is on page 205 of the manual, the section labeled “Remote User Access”
Cheers,
Z
