I’m reaching out to see if there are alternative solutions to replicate the functionality of the BR2. I’ve been considering a setup involving two BR1 devices connected to a Peplink 20X in a bridge configuration. I’m uncertain about the viability of this approach. I would be grateful for any insights or recommendations you may have.
What functionality do you actually want to replicate? Having 2 cellular WAN connections? That is even possible with two BR1 devices without the 20X, using VLAN as WAN and eventually synergy mode. Or do you require more? Docker is only on the BR2 and the real LAN ports stay limited, but that’s also easy to solve. The question is: how much (more) do you want to craft yourself instead of having an integrated solution?
