Dear Guys ,
consider the following network chart :
Here is the goals :
1- connecting two sites to each other so that all VLANs can see each other.
2- both microwave links ( 2 x 375 Mbps) must be used at the same time with load balancing and fail over.
please give me some advice. in my mind we should use 2x BPL-2500 so that we could achieve 750Mbps SF throughput, but I wanted to share it with you and see if you have any advice.
and here is a question : How much packet overhead we have on this amount of bandwidth when using SF ? 10% ? 15 % ?
Thanks - Hootan
