SOHO Switch
I would like Peplink to create a SOHO switch (5 port). I’ve had trouble getting VLANs defined in my Peplink devices working properly with third party switches, but the cheapest Peplink switch (which is 8 ports) is $599, which is 3 times as expensive as the SOHO MK3. Obviously, I could buy another SOHO and use that as a switch, but $200 for a 5-port switch is way overpriced.
I want to be able to connect a switch to my SOHO or Balance 20X and configure certain ports on the switch to be Trunk ports to allow any VLANs (such as a port connected to my AP One) and configure certain ports on the switch to force connected devices to be on VLANs defined in the SOHO/Balance 20X (e.g., VLAN ID 2, VLAN ID 5, etc.).
Literally any switch that supports 802.1q can do this… whether that’s a Peplink or not.
Whilst we do use Peplink switches in some places where the client wants a single management platform, or does not require any advanced features (the Peplink switches are mostly used as basic L2 switches at the moment) but in the vast majority of times it’s a Cisco Catalyst or HPE/Aruba switch on the other side and it just works.
In what way are you struggling - maybe we can help you get it working? :slight_smile:
I use UBNT products like the flex mini ($30) and US-8-60W for POE. They work flawlessly, but you have to run UBNT’s mangement platorm to configure the mini. I just assign one to a docker.
I have a MikroTik RB260GS switch that I have tried, unsuccessfully, to work the way I want it to in my current Peplink environment. Admittedly, it is probably 100% user ignorance/error on my part. I find the MikroTik interface and documentation confusing and less user-friendly than Peplink’s.
I have port 1 of the RB260GS connected to one of the LAN ports on my Peplink router, with the router configured to treat that port as Trunk and allow any VLANs. I want inter-VLAN routing rules to be handled by the Peplink router, not the switch.
This is how I want the RB260GS to handle traffic:
  • Port 1 (this is the connection back to the router): allow any traffic in/out with no changes re VLAN tagging
  • Port 2 (connected to a Peplink AP One Wi-Fi AP): allow any traffic in/out with no changes re VLAN tagging so that the AP One can control VLAN assignments based on the SSID
  • Ports 3 and 4: make all devices using this port be assigned to VLAN 2 (such that the Peplink router will see them as on VLAN 2 and assign an IP address for VLAN 2)
  • Port 5: make all devices using this port be assigned to VLAN 3 (such that the Peplink router will see them as on VLAN 2 and assign an IP address for VLAN 3)
It would just be nice to have a basic (not expensive) 5-port Peplink managed switch that could be easily configured like the Peplink routers–or even managed by the Peplink routers.
Hi, yeah I wouldn’t mind buying a cheap Peplink Switch to make things easier in the one environment. I’m trying to get an old Cisco 8-Port switch working at the moment without much success.
Stupid thing is, I can get these switches working no problem when using a Cisco Router.
I have multiple VLANs on the Balance 20 and I have set up a trunk port on both sides but can’t yet communicate. Got the same VLANs on the Cisco Switch too. However, the primary VLAN is set to ‘None’ whereas the other VLANs each have a number associated with them. Has anyone got any useful guides or tutorials they could point me to please?
I agree, I’d like to see a switch (6-8 port) that works seamlessly with the Peplink B-One router, and be able to handle VLANs. The B-One router is $299, so a switch should probably be priced less than that.
Hello @peppypeplink,
Outside of current range of Peplink SD-Switches, if we need a cost-effective switch that handles IEEE 802.1Q for small deployments (say, 4 or 5 ports), we have often sourced a NetGear Gigabit Plus Switch Series (GS105Ev2). Now, with the new Peplink InTouch, you can remotely administer these through the Peplink InControl2.
Happy to Help,
Marcus :slight_smile:
Agree - they work great!
Or else there’s also the Cisco CB-Range.
They’re good value !
Hi all. First post on this forum as a new Peplink adopter. just thought I would add some findings on the end of Marcus’ post for anyone interested. I need to use L2 switches that handle VLANs and can deliver both active and passive PoE. I found the following info that others may find useful.
Netonix WISP switches L2 PoE Passive Mode B - supports 802.1Q VLANS and 802.3 active PoE devices (configurable for passive 48V and passive 24V)
Ubiquiti Edgeswitch Devices - 8 port supports 802.1Q VLANS as well as 24V and 48 passive PoE
Ubiquiti Edgeswitch Devices - 5 Port - supports 802.1Q VLANs and 24V Passive Poe Only
All of these devices are running on my network lab and i am manging these from Intouch via the Peplink. I can also confirm that Unifi devices will not permit management without the Unifi controller
Thanks @phendrickse,
Appreciate your contributing to the discussion from your tests and observations.
Welcome to the Peplik Community Forum
Happy to Help,
This is my “wishlist” for peplink switching:
SOHO
Cheap switches that are basic. The selling point here is single pain of glass management in incontrol2.
Minimum viable product here is 1gb switches with POE & VLANs. Single PSU, no local console. Priced to sell with a bOne/b20x.
Once MVP is met, desirability here is:
mlag
2.5gb ports
usb for UPS monitoring
dynamic vlan config
what I’d like to see:
4 port POE in (4x 1Gb RJ45, 1 does POE in, 3 do POE out)
8 port (8x 1Gb RJ45, all with .at 30w POE out, 2x 1Gb SFP, single PSU)
24 port (24x 1Gb RJ45, all with .at 30w POE out, 2x 10Gb SFP, single PSU)
48 port (48x 1Gb RJ45, all with .at 30w POE out, 2 or 4x 10Gb SFP, single PSU)
Rugged
The existing line does well here. We use this in Fiji where the temp range can get wider, and we want reliability. The biggest problems are actually small quality of life things like the brackets being annoying & the power plugs sticking out to far.
In an ideal world I would like to see the existing line get:
shuttered ports
accept 12v in and still do 48v poe out
the 8 port and 16 port use the same bracket, which has space to hold the PSUs on it
The PSU plug not stick out so far (the terminal block does help)
16 port have poe on all ports & NOT share port 15 with copper/fibre (it can’t do lacp on 2x fibre ports)
mlag
dynamic vlan config
in an mgig world, perhaps the above feature in a range like this:
5 port POE in (4x 1Gb RJ45, 2 do 60w POE in, 3 do POE out, plenum rated, shuttered RJ45 ports, DIN rail mount)
8 port (6x 1Gb RJ45 30w POE out, 2x 2.5Gb with 60w POE out, 2x 1Gb SFP, dual PSU, GPIO, shuttered RJ45 ports)
16 port (12x 1Gb RJ45 30w POE out, 4x 2.5Gb with 60w POE out, 2x 1Gb SFP, dual PSU, GPIO, shuttered RJ45 ports)
24 port (16x 1Gb RJ45 30w POE out, 8x 2.5Gb with 60w POE out, 4x 10/25Gb SFP, dual PSU, GPIO, shuttered RJ45 ports)
Access point wise I really want two things here:
  • An ap like the ap ax lite with an SFP port (ie it has rj45 poe in, and sfp/dc in)
  • A proper outdoor AP. I envisage this as a two-part unit, a radio unit that has rj45, sfp & dc and antenna ports that clips into peplink antennas and forms a modular outdoor IP67 ap with no antenna cables. the antennas could be chosen for the specific deployment, like:
    360 degree omni
    180 degree panel
    120 degree panel
    60 degree panel
Enterprise
This is about bigger deployments. Rack mount, dual PSU, all POE, mgig, mlag are all minimum viable product here. They don’t have to be 100% mgig, they could be mostly 1gb with a third or half the ports being mgig if that made a big difference price wise.
Some sort of mlag/stacking/fabric is required to get redundancy on the LAN side. I have lots of deployments where I want redundancy, I can have HA peplinks but to have redundancy from the peplink->lan I have to able to connect the peplink to 2x switches lan side and its risky to use STP for that. I need to be able to have an LACP from the peplink sd-wan where each leg ends on two separate switches.
3 port 1 Gb HA switch/dongle (2 ports POE in, 1 no POE or POE out). For connecting a wan to 2x peplinks in HA. POE powered from both peplinks, monitored by the peplinks with something like synergy mode.
16 port (16x 1/2.5Gb or 1/2.5/5gb with 60w POE out, 2x 25Gb SFP, dual PSU, MLAG, stacking or fabric)
24 port (24x 1/2.5Gb or 1/2.5/5gb with 60w POE out, 4x 25Gb SFP, dual PSU, MLAG, stacking or fabric)
48 port (48x 1/2.5Gb or 1/2.5/5gb with 60w POE out, 4x 25Gb SFP, dual PSU, MLAG, stacking or fabric)
Fibre switch (24 or 48x SFP28 supporting 1/10/25gb + 6-8x QSFP28 100G ports, dual hot swappable PSU, selectable fan direction, MLAG minimum but prefer stacking)
The ++ level here would be:
  • USB UPS monitoring
  • dynamic vlan config
  • Fabric “SD-LAN”.
Access point wise:
  • AP AX Lite but wifi7 and a second ethernet port that does POE out
  • AP AX but wifi7 and 2x multigig ports that both do POE in for deployments doing LACP (or passive LAG) from 2x mlag switches to have switch redundancy for the AP
Thank you for your interest in the Surf SOHO. Please note that it has reached its end of sales. You can find more information here.
As the successor, we recommend the B One series, which offers enhanced performance and updated capabilities. You can learn more about it here. Additionally, we have introduced a new series of switches, and more details can be found here.
If you need additional support, please feel free to contact [email protected], and we will be happy to assist or connect you with one of our partners.
