[TABLE=“class: form_table”]
[TR=“class: tablecontent2”]
Router Name
Z21_2GWVistas
[/TR]
Model
Pepwave Surf SOHO
[/TR]
Product Code
SUS-SOHO
[/TR]
Hardware Revision
1
[/TR]
Serial Number
2830-F438-6630
[/TR]
Firmware
6.1.2 build 1539
[/TR]
PepVPN Version
3.0.0
[/TR]
Modem Support Version
1015 (Modem Support List)
[/TR]
Host Name
z21-2gwvistas
[/TR]
Uptime
3 hours 11 minutes
[/TR]
System Time
Mon Jul 21 17:01:12 EDT 2014
[/TR]
[/TABLE]
RA is on report attached.
SOHO doesn’t allow to save outbound rule:
Advanced> PepVPN Outbound Custom Rules > Add Rule>
> name > source - any > Destination - domain name " pbx.pangeaequity.com" >
Algorithm - Priority > Connections - WAN secondary VPN.
Hit “Save” rule doesn’t exist!
Apply changes and in the Dashboard {Changes pending. Discard changes]}
active. Apply changes doesn’t make desired behavior on traffic rule and rules doesn’t appear ether.
opened ticket with report
[Ticket #743674] SOHO doesn’t allow to save outbound rule:
Hi Andrey,
Noted. Will look into this.
Hi Andrey,
This is known issue on v6.1.2 RC and will be fixed in v6.1.2 GA.
will this include a fix to honor rule by domain name and not by IP?
doubt!
in this ticket I opened I specifically described what I was doing and it doesn’t work.
If its a GUI that I would see my VOIP traffic routed properly
If Rule just nor shown in the GUI but like you said rules are there then my SIP endpoint
should send registration request over VPN and its not happening.
SIP EndPoints 10.121.2.60 and 10.121.2.61 goes over USB to 184.170.32.28 which is pbx.pangeaequity.com
Hi Andrey,
Your Outbound Rules are below but all these never showed in GUI as I mentioned earlier:-
<Outbound Rules omitted, Please refer to ticket>
The rule not working accordingly is due to the problem of Balance does not store the requested domain and IP. This problem still under investigation.
Hate to bother on this, is the fix will be out pretty soon?
The firmware with the fix will be release very soon, and we will definitely inform you once it is available.
Hi Andrey,
Appreciate if you can download this firmware http://download.peplink.com/firmware/plb1/fw-b1_hd4-6.1.2s24-build1598.bin to solve the problem of Outbound Policy by domain name and Outbound Rules not show in Gui.
this is firmware not for SOHO but this is b1
Hi Andrey,
Sorry I overlook on this. Will provide the special build for Soho later.
no problem we pretty busy here too ![:slight_smile: :slight_smile:](//forum.peplink.com/images/emoji/twitter/slight_smile.png?v=12)
