Software License Activation FAQ
Q: How do I check if my license has been activated?
1. InControl
  • Log in to InControl. Under Device Details, find Feature Activation and click Show. Activated licenses will be listed here.
2. Event Log
  • Log in to InControl. Under Device Details, find History, and click Event Log. Recently activated licenses will be listed here.
  • Alternatively. You can find the same Event Log in the Web Admin settings, under Status > Event Log.
Q: What should I do if my license wasn’t activated automatically?
  • Login to your Web Admin settings and find the feature activation page under System > Feature Add-ons. Input the license key in the Activation Key box to activate the license manually.
Q: How can I check if my device has any associated license(s) and what my License Key is?
1. Order Confirmation Email
  • In the order confirmation email (“Your Order with Peplink #AE……”), the license key is provided for your reference.
2. Peplink Portal
  • Login to the Peplink Portal
  • Click on Device Management and search for your device’s serial number (S/N).
  • Click on the S/N’s corresponding action button.
  • If the S/N has any associated licenses it will appear in the Services tab.
