lucask
1
I am trying to set up the Facebook login using AP One’s controlled by a balance 20.
I do not see the options to configure this anywhere like I do through InControl on a Balance One.
Firmware on both the router and APs are up to date 6.2.1 and 3.5.2
What am I missing?
Currently Social Wi-Fi Hotspot is only configurable via InControl2.
lucask
3
I see. What is the best way to go about moving AP management from the router into InControl?
If I disable the AP controller in the balance 20, will management automatically go to incontrol if the serial is registered?
lucask
4
nevermind. i got it. I had to set up remote access so i could log into the AP directly and change the controller to InControl
