I am monitoring my Balance 380 with PRTG. I have found the MIBs and used the MIB Importer tool from PRTG to change the MIB to the OIDLIB that PRTG uses for monitoring. This works great. However, most of the information is pretty useless. Most of the sensor values are just a single digit number that almost assuredly means something to the Peplink, but has no value lookup for PRTG to display the information in plain language that would mean something to me.
Sensors such as “port wan speed index” and “port wan speed” display just a 1 at this point. I have to assume that means something like 100FD (100 full duplex) or 1000FD (1000 full duplex) however the MIB and OIDLIB are not getting any of those values to pass to PRTG.
Thanks, but that is not it. I need to discover what the Integer value represents in general information so I can write a lookup value for PRTG to use so the information is more user friendly.
For example, if the query returns a 1 when it checks WAN speed PRTG will actually show that the WAN speed is 1Gbps, or a 2 means 100Mbps, and so on. The integer value that is returned does me little good as I don’t know what it represents.
