i want to monitor the traffic of a Cellular Connection with PRTG.
Unfortunately when i try to add a SNMP traffic sensor i only can choose the cabeled wan interfaces, not the cellular ports.
I also tried to use the pepwave mib, but with that im not able to monitor any traffic.
I tried to add sensors when the cellular was active and when it was backup.
Both times i could only create sensors for other WAN connections out of cellular.
I am quickly running out of ideas. Have you played with the Peplink device MIB? It may have some extended OID for the cellular connections. I don’t know for sure, but it is worth taking a look.
Im having the same issue. I cannot even get the WAN sensors to work. Im running 6.3 and using the correct MIB but still get nothing. What am I doing wrong here?
