Hi all,
I am using PRTG monitor. I want to add a sensors for peplink device CPU/RAM. but I do not found the OID. Anyone can help me How to found it?
Thank a lot!!!
Hi all,
Thank a lot!!!
You can download the SNMP MIB from here:
Thank of you reply. I found the Peplink Balance SNMP Private MIB for 6.1 or above (Updated at Apr 22, 2015). But i can not see any about cpu/memory keyword. My device are Balance 710/1250/2500.Which one MIB file should be right?
Hi Gary,
Please refer to the forum thread SNMP CPU/Memory to monitor CPU and memory usage for Balance device.
Private SNMP MIB for CPU & Memory usage tentatively will be available for firmware 6.3
Thank You
Thank of you reply! you mean that I only need to see a common HOST-RESOURCES-MIB.oid, It will be done?
Hi Gary,
The requires OIDs are included in the previous given forum threads.
Memory
HOST-RESOURCES-MIB
CPU
UCD-SNMP-MIB
System Stat .1.3.6.1.4.1.2021.11
Thank You
Não tive retorno com esses dados na memoria, storage e cpu.
O seu deu certo?
Estou querendo monitorar um PepLink modelo 710 com o Zabbix. Consegui pegar um template padrão do snmp2 que vem com o zabbix e obter algumas informaçoes. Porém ainda está faltando o CPU, Memoria e Storage.
Tenho essas informaçoes dele:
PS: Estou usando o Zabbix 3.4 e Centos 7
#snmpwalk -v2c -c
SNMPv2-MIB::sysDescr.0 = STRING: Peplink Balance Series
SNMPv2-MIB::sysObjectID.0 = OID: NET-SNMP-MIB::netSnmpAgentOIDs.10
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (219756958) 25 days, 10:26:09.5 8
SNMPv2-MIB::sysContact.0 = STRING: not specified
SNMPv2-MIB::sysName.0 = STRING: JAMEL710
SNMPv2-MIB::sysLocation.0 = STRING: Peplink
SNMPv2-MIB::sysORLastChange.0 = Timeticks: (0) 0:00:00.00
SNMPv2-MIB::sysORID.1 = OID: SNMPv2-MIB::snmpMIB
SNMPv2-MIB::sysORID.2 = OID: SNMP-VIEW-BASED-ACM-MIB::vacmBasicGroup
SNMPv2-MIB::sysORID.3 = OID: SNMP-FRAMEWORK-MIB::snmpFrameworkMIBCompliance
SNMPv2-MIB::sysORID.4 = OID: SNMP-MPD-MIB::snmpMPDCompliance
SNMPv2-MIB::sysORID.5 = OID: SNMP-USER-BASED-SM-MIB::usmMIBCompliance
SNMPv2-MIB::sysORID.6 = OID: IF-MIB::ifMIB
SNMPv2-MIB::sysORID.7 = OID: TCP-MIB::tcpMIB
SNMPv2-MIB::sysORID.8 = OID: IP-MIB::ip
SNMPv2-MIB::sysORID.9 = OID: UDP-MIB::udpMIB
SNMPv2-MIB::sysORDescr.1 = STRING: The MIB module for SNMPv2 entities
SNMPv2-MIB::sysORDescr.2 = STRING: View-based Access Control Model for SNMP.
SNMPv2-MIB::sysORDescr.3 = STRING: The SNMP Management Architecture MIB.
SNMPv2-MIB::sysORDescr.4 = STRING: The MIB for Message Processing and Dispatchin g.
SNMPv2-MIB::sysORDescr.5 = STRING: The management information definitions for th e SNMP User-based Security Model.
SNMPv2-MIB::sysORDescr.6 = STRING: The MIB module to describe generic objects fo r network interface sub-layers
SNMPv2-MIB::sysORDescr.7 = STRING: The MIB module for managing TCP implementatio ns
SNMPv2-MIB::sysORDescr.8 = STRING: The MIB module for managing IP and ICMP imple mentations
SNMPv2-MIB::sysORDescr.9 = STRING: The MIB module for managing UDP implementatio ns
SNMPv2-MIB::sysORUpTime.1 = Timeticks: (0) 0:00:00.00
SNMPv2-MIB::sysORUpTime.2 = Timeticks: (0) 0:00:00.00
SNMPv2-MIB::sysORUpTime.3 = Timeticks: (0) 0:00:00.00
SNMPv2-MIB::sysORUpTime.4 = Timeticks: (0) 0:00:00.00
SNMPv2-MIB::sysORUpTime.5 = Timeticks: (0) 0:00:00.00
SNMPv2-MIB::sysORUpTime.6 = Timeticks: (0) 0:00:00.00
SNMPv2-MIB::sysORUpTime.7 = Timeticks: (0) 0:00:00.00
SNMPv2-MIB::sysORUpTime.8 = Timeticks: (0) 0:00:00.00
SNMPv2-MIB::sysORUpTime.9 = Timeticks: (0) 0:00:00.00
IF-MIB::ifNumber.0 = INTEGER: 9
IF-MIB::ifIndex.1 = INTEGER: 1
IF-MIB::ifIndex.2 = INTEGER: 2
IF-MIB::ifIndex.3 = INTEGER: 3
IF-MIB::ifIndex.4 = INTEGER: 4
IF-MIB::ifIndex.5 = INTEGER: 5
IF-MIB::ifIndex.6 = INTEGER: 6
IF-MIB::ifIndex.7 = INTEGER: 7
IF-MIB::ifIndex.8 = INTEGER: 8
IF-MIB::ifDescr.1 = STRING: LAN
IF-MIB::ifDescr.2 = STRING: WAN1
IF-MIB::ifDescr.3 = STRING: WAN2
IF-MIB::ifDescr.4 = STRING: WAN3
IF-MIB::ifDescr.5 = STRING: WAN4
IF-MIB::ifDescr.6 = STRING: WAN5
IF-MIB::ifDescr.7 = STRING: WAN6
IF-MIB::ifDescr.8 = STRING: WAN7
IF-MIB::ifType.1 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifType.2 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifType.3 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifType.4 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifType.5 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifType.6 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifType.7 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifType.8 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifMtu.1 = INTEGER: 1500
IF-MIB::ifMtu.2 = INTEGER: 1500
IF-MIB::ifMtu.3 = INTEGER: 1440
IF-MIB::ifMtu.4 = INTEGER: 1440
IF-MIB::ifMtu.5 = INTEGER: 1440
IF-MIB::ifMtu.6 = INTEGER: 1440
IF-MIB::ifMtu.7 = INTEGER: 1440
IF-MIB::ifMtu.8 = INTEGER: 1440
IF-MIB::ifSpeed.1 = Gauge32: 1000000000
IF-MIB::ifSpeed.2 = Gauge32: 100000000
IF-MIB::ifSpeed.3 = Gauge32: 10000000
IF-MIB::ifSpeed.4 = Gauge32: 10000000
IF-MIB::ifSpeed.5 = Gauge32: 10000000
IF-MIB::ifSpeed.6 = Gauge32: 10000000
IF-MIB::ifSpeed.7 = Gauge32: 10000000
IF-MIB::ifSpeed.8 = Gauge32: 10000000
IF-MIB::ifPhysAddress.1 = STRING: 10:56:ca:9:b:5c
IF-MIB::ifPhysAddress.2 = STRING: 10:56:ca:9:b:5d
IF-MIB::ifPhysAddress.3 = STRING: 10:56:ca:9:b:5e
IF-MIB::ifPhysAddress.4 = STRING: 10:56:ca:9:b:5f
IF-MIB::ifPhysAddress.5 = STRING: 10:56:ca:9:b:60
IF-MIB::ifPhysAddress.6 = STRING: 10:56:ca:9:b:61
IF-MIB::ifPhysAddress.7 = STRING: 10:56:ca:9:b:62
IF-MIB::ifPhysAddress.8 = STRING: 10:56:ca:9:b:63
IF-MIB::ifAdminStatus.1 = INTEGER: up(1)
IF-MIB::ifAdminStatus.2 = INTEGER: up(1)
IF-MIB::ifAdminStatus.3 = INTEGER: down(2)
IF-MIB::ifAdminStatus.4 = INTEGER: down(2)
IF-MIB::ifAdminStatus.5 = INTEGER: down(2)
IF-MIB::ifAdminStatus.6 = INTEGER: down(2)
IF-MIB::ifAdminStatus.7 = INTEGER: down(2)
IF-MIB::ifAdminStatus.8 = INTEGER: down(2)
IF-MIB::ifOperStatus.1 = INTEGER: up(1)
IF-MIB::ifOperStatus.2 = INTEGER: up(1)
IF-MIB::ifOperStatus.3 = INTEGER: up(1)
IF-MIB::ifOperStatus.4 = INTEGER: up(1)
IF-MIB::ifOperStatus.5 = INTEGER: up(1)
IF-MIB::ifOperStatus.6 = INTEGER: up(1)
IF-MIB::ifOperStatus.7 = INTEGER: up(1)
IF-MIB::ifOperStatus.8 = INTEGER: up(1)
IF-MIB::ifInOctets.1 = Counter32: 849145470
IF-MIB::ifInOctets.2 = Counter32: 1403485588
IF-MIB::ifInOctets.3 = Counter32: 0
IF-MIB::ifInOctets.4 = Counter32: 0
IF-MIB::ifInOctets.5 = Counter32: 0
IF-MIB::ifInOctets.6 = Counter32: 0
IF-MIB::ifInOctets.7 = Counter32: 0
IF-MIB::ifInOctets.8 = Counter32: 0
IF-MIB::ifInUcastPkts.1 = Counter32: 713151458
IF-MIB::ifInUcastPkts.2 = Counter32: 668695552
IF-MIB::ifInUcastPkts.3 = Counter32: 0
IF-MIB::ifInUcastPkts.4 = Counter32: 0
IF-MIB::ifInUcastPkts.5 = Counter32: 0
IF-MIB::ifInUcastPkts.6 = Counter32: 0
IF-MIB::ifInUcastPkts.7 = Counter32: 0
IF-MIB::ifInUcastPkts.8 = Counter32: 0
IF-MIB::ifInDiscards.1 = Counter32: 0
IF-MIB::ifInDiscards.2 = Counter32: 0
IF-MIB::ifInDiscards.3 = Counter32: 0
IF-MIB::ifInDiscards.4 = Counter32: 0
IF-MIB::ifInDiscards.5 = Counter32: 0
IF-MIB::ifInDiscards.6 = Counter32: 0
IF-MIB::ifInDiscards.7 = Counter32: 0
IF-MIB::ifInDiscards.8 = Counter32: 0
IF-MIB::ifInErrors.1 = Counter32: 4
IF-MIB::ifInErrors.2 = Counter32: 0
IF-MIB::ifInErrors.3 = Counter32: 0
IF-MIB::ifInErrors.4 = Counter32: 0
IF-MIB::ifInErrors.5 = Counter32: 0
IF-MIB::ifInErrors.6 = Counter32: 0
IF-MIB::ifInErrors.7 = Counter32: 0
IF-MIB::ifInErrors.8 = Counter32: 0
IF-MIB::ifOutOctets.1 = Counter32: 1048727716
IF-MIB::ifOutOctets.2 = Counter32: 1737954891
IF-MIB::ifOutOctets.3 = Counter32: 0
IF-MIB::ifOutOctets.4 = Counter32: 0
IF-MIB::ifOutOctets.5 = Counter32: 0
IF-MIB::ifOutOctets.6 = Counter32: 0
IF-MIB::ifOutOctets.7 = Counter32: 0
IF-MIB::ifOutOctets.8 = Counter32: 0
IF-MIB::ifOutUcastPkts.1 = Counter32: 670786041
IF-MIB::ifOutUcastPkts.2 = Counter32: 742653794
IF-MIB::ifOutUcastPkts.3 = Counter32: 0
IF-MIB::ifOutUcastPkts.4 = Counter32: 0
IF-MIB::ifOutUcastPkts.5 = Counter32: 0
IF-MIB::ifOutUcastPkts.6 = Counter32: 0
IF-MIB::ifOutUcastPkts.7 = Counter32: 0
IF-MIB::ifOutUcastPkts.8 = Counter32: 0
IF-MIB::ifOutDiscards.1 = Counter32: 0
IF-MIB::ifOutDiscards.2 = Counter32: 0
IF-MIB::ifOutDiscards.3 = Counter32: 0
IF-MIB::ifOutDiscards.4 = Counter32: 0
IF-MIB::ifOutDiscards.5 = Counter32: 0
IF-MIB::ifOutDiscards.6 = Counter32: 0
IF-MIB::ifOutDiscards.7 = Counter32: 0
IF-MIB::ifOutDiscards.8 = Counter32: 0
IF-MIB::ifOutErrors.1 = Counter32: 0
IF-MIB::ifOutErrors.2 = Counter32: 0
IF-MIB::ifOutErrors.3 = Counter32: 0
IF-MIB::ifOutErrors.4 = Counter32: 0
IF-MIB::ifOutErrors.5 = Counter32: 0
IF-MIB::ifOutErrors.6 = Counter32: 0
IF-MIB::ifOutErrors.7 = Counter32: 0
IF-MIB::ifOutErrors.8 = Counter32: 0
IF-MIB::ifOutQLen.1 = Gauge32: 0
IF-MIB::ifOutQLen.2 = Gauge32: 0
IF-MIB::ifOutQLen.3 = Gauge32: 0
IF-MIB::ifOutQLen.4 = Gauge32: 0
IF-MIB::ifOutQLen.5 = Gauge32: 0
IF-MIB::ifOutQLen.6 = Gauge32: 0
IF-MIB::ifOutQLen.7 = Gauge32: 0
IF-MIB::ifOutQLen.8 = Gauge32: 0
IF-MIB::ifSpecific.1 = OID: SNMPv2-SMI::zeroDotZero
IF-MIB::ifSpecific.2 = OID: SNMPv2-SMI::zeroDotZero
IF-MIB::ifSpecific.3 = OID: SNMPv2-SMI::zeroDotZero
IF-MIB::ifSpecific.4 = OID: SNMPv2-SMI::zeroDotZero
IF-MIB::ifSpecific.5 = OID: SNMPv2-SMI::zeroDotZero
IF-MIB::ifSpecific.6 = OID: SNMPv2-SMI::zeroDotZero
IF-MIB::ifSpecific.7 = OID: SNMPv2-SMI::zeroDotZero
IF-MIB::ifSpecific.8 = OID: SNMPv2-SMI::zeroDotZero
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.3 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.4 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.7 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.9 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.13 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.14 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.16 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.17 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.19 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.21 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.29 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.30 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.31 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.33 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.57 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.59 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.62 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.63 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.71 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.78 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.79 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.85 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.107 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.109 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.1.1.10.10.3.111 = INTEGER: 1
SNMPv2-SMI::mib-2.3.1.1.1.2.1.201.16.193.158 = INTEGER: 2
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.3 = Hex-STRING: 00 15 5D 03 5F 05
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.4 = Hex-STRING: 00 15 5D 03 17 16
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.7 = Hex-STRING: A4 5D 36 29 F7 B8
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.9 = Hex-STRING: 00 15 5D 00 78 02
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.13 = Hex-STRING: 00 15 5D 03 17 20
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.14 = Hex-STRING: 00 15 5D 03 17 05
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.16 = Hex-STRING: 00 15 5D 03 17 00
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.17 = Hex-STRING: 00 15 5D 03 5A 01
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.19 = Hex-STRING: 00 15 5D 03 0F 10
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.21 = Hex-STRING: 00 1C C0 8D 7A 6D
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.29 = Hex-STRING: 00 15 5D 03 65 05
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.30 = Hex-STRING: 00 15 5D 03 17 26
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.31 = Hex-STRING: 00 1E 67 3C 7B F2
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.33 = Hex-STRING: 00 15 5D 03 4F 01
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.57 = Hex-STRING: 00 15 5D 00 01 11
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.59 = Hex-STRING: 00 15 5D 03 0F 01
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.62 = Hex-STRING: 00 15 5D 03 0F 09
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.63 = Hex-STRING: E8 40 F2 3A 3E B2
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.71 = Hex-STRING: 00 15 5D 03 5F 01
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.78 = Hex-STRING: 00 15 5D 00 01 05
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.79 = Hex-STRING: 00 15 17 DA BE 71
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.85 = Hex-STRING: 00 0C 29 42 49 63
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.107 = Hex-STRING: 00 15 5D 03 0F 12
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.109 = Hex-STRING: 00 15 5D 00 78 00
SNMPv2-SMI::mib-2.3.1.1.2.1.1.10.10.3.111 = Hex-STRING: 00 15 5D 00 78 07
SNMPv2-SMI::mib-2.3.1.1.2.2.1.201.16.193.158 = Hex-STRING: B8 AF 67 F7 8A 88
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.3 = IpAddress: 10.10.3.3
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.4 = IpAddress: 10.10.3.4
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.7 = IpAddress: 10.10.3.7
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.9 = IpAddress: 10.10.3.9
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.13 = IpAddress: 10.10.3.13
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.14 = IpAddress: 10.10.3.14
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.16 = IpAddress: 10.10.3.16
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.17 = IpAddress: 10.10.3.17
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.19 = IpAddress: 10.10.3.19
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.21 = IpAddress: 10.10.3.21
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.29 = IpAddress: 10.10.3.29
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.30 = IpAddress: 10.10.3.30
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.31 = IpAddress: 10.10.3.31
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.33 = IpAddress: 10.10.3.33
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.57 = IpAddress: 10.10.3.57
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.59 = IpAddress: 10.10.3.59
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.62 = IpAddress: 10.10.3.62
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.63 = IpAddress: 10.10.3.63
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.71 = IpAddress: 10.10.3.71
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.78 = IpAddress: 10.10.3.78
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.79 = IpAddress: 10.10.3.79
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.85 = IpAddress: 10.10.3.85
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.107 = IpAddress: 10.10.3.107
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.109 = IpAddress: 10.10.3.109
SNMPv2-SMI::mib-2.3.1.1.3.1.1.10.10.3.111 = IpAddress: 10.10.3.111
SNMPv2-SMI::mib-2.3.1.1.3.2.1.201.16.193.158 = IpAddress: 201.16.193.158
IP-MIB::ipAdEntAddr.10.10.3.5 = IpAddress: 10.10.3.5
IP-MIB::ipAdEntAddr.201.16.193.153 = IpAddress: 201.16.193.153
IP-MIB::ipAdEntAddr.201.16.193.154 = IpAddress: 201.16.193.154
IP-MIB::ipAdEntAddr.201.16.193.155 = IpAddress: 201.16.193.155
IP-MIB::ipAdEntAddr.201.16.193.156 = IpAddress: 201.16.193.156
IP-MIB::ipAdEntAddr.201.16.193.157 = IpAddress: 201.16.193.157
IP-MIB::ipAdEntIfIndex.10.10.3.5 = INTEGER: 1
IP-MIB::ipAdEntIfIndex.201.16.193.153 = INTEGER: 2
IP-MIB::ipAdEntIfIndex.201.16.193.154 = INTEGER: 2
IP-MIB::ipAdEntIfIndex.201.16.193.155 = INTEGER: 2
IP-MIB::ipAdEntIfIndex.201.16.193.156 = INTEGER: 2
IP-MIB::ipAdEntIfIndex.201.16.193.157 = INTEGER: 2
IP-MIB::ipAdEntNetMask.10.10.3.5 = IpAddress: 255.255.255.0
IP-MIB::ipAdEntNetMask.201.16.193.153 = IpAddress: 255.255.255.248
IP-MIB::ipAdEntNetMask.201.16.193.154 = IpAddress: 255.255.255.255
IP-MIB::ipAdEntNetMask.201.16.193.155 = IpAddress: 255.255.255.255
IP-MIB::ipAdEntNetMask.201.16.193.156 = IpAddress: 255.255.255.255
IP-MIB::ipAdEntNetMask.201.16.193.157 = IpAddress: 255.255.255.255
IP-MIB::ipAdEntBcastAddr.10.10.3.5 = INTEGER: 0
IP-MIB::ipAdEntBcastAddr.201.16.193.153 = INTEGER: 0
IP-MIB::ipAdEntBcastAddr.201.16.193.154 = INTEGER: 0
IP-MIB::ipAdEntBcastAddr.201.16.193.155 = INTEGER: 0
IP-MIB::ipAdEntBcastAddr.201.16.193.156 = INTEGER: 0
IP-MIB::ipAdEntBcastAddr.201.16.193.157 = INTEGER: 0
IP-MIB::ip.21.1.1.10.10.3.0 = IpAddress: 10.10.3.0
IP-MIB::ip.21.1.1.201.16.193.152 = IpAddress: 201.16.193.152
IP-MIB::ip.21.1.2.10.10.3.0 = INTEGER: 1
IP-MIB::ip.21.1.2.201.16.193.152 = INTEGER: 2
IP-MIB::ip.21.1.3.10.10.3.0 = INTEGER: 0
IP-MIB::ip.21.1.3.201.16.193.152 = INTEGER: 0
IP-MIB::ip.21.1.7.10.10.3.0 = IpAddress: 0.0.0.0
IP-MIB::ip.21.1.7.201.16.193.152 = IpAddress: 0.0.0.0
IP-MIB::ip.21.1.8.10.10.3.0 = INTEGER: 3
IP-MIB::ip.21.1.8.201.16.193.152 = INTEGER: 3
IP-MIB::ip.21.1.9.10.10.3.0 = INTEGER: 2
IP-MIB::ip.21.1.9.201.16.193.152 = INTEGER: 2
IP-MIB::ip.21.1.11.10.10.3.0 = IpAddress: 255.255.255.0
IP-MIB::ip.21.1.11.201.16.193.152 = IpAddress: 255.255.255.248
IP-MIB::ip.21.1.13.10.10.3.0 = OID: SNMPv2-SMI::zeroDotZero
IP-MIB::ip.21.1.13.201.16.193.152 = OID: SNMPv2-SMI::zeroDotZero
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.3 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.4 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.7 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.9 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.13 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.14 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.16 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.17 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.19 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.21 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.29 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.30 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.31 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.33 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.57 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.59 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.62 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.63 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.71 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.78 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.79 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.85 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.107 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.109 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.1.10.10.3.111 = INTEGER: 1
IP-MIB::ipNetToMediaIfIndex.2.201.16.193.158 = INTEGER: 2
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.3 = STRING: 0:15:5d:3:5f:5
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.4 = STRING: 0:15:5d:3:17:16
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.7 = STRING: a4:5d:36:29:f7:b8
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.9 = STRING: 0:15:5d:0:78:2
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.13 = STRING: 0:15:5d:3:17:20
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.14 = STRING: 0:15:5d:3:17:5
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.16 = STRING: 0:15:5d:3:17:0
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.17 = STRING: 0:15:5d:3:5a:1
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.19 = STRING: 0:15:5d:3:f:10
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.21 = STRING: 0:1c:c0:8d:7a:6d
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.29 = STRING: 0:15:5d:3:65:5
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.30 = STRING: 0:15:5d:3:17:26
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.31 = STRING: 0:1e:67:3c:7b:f2
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.33 = STRING: 0:15:5d:3:4f:1
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.57 = STRING: 0:15:5d:0:1:11
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.59 = STRING: 0:15:5d:3:f:1
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.62 = STRING: 0:15:5d:3:f:9
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.63 = STRING: e8:40:f2:3a:3e:b2
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.71 = STRING: 0:15:5d:3:5f:1
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.78 = STRING: 0:15:5d:0:1:5
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.79 = STRING: 0:15:17:da:be:71
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.85 = STRING: 0:c:29:42:49:63
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.107 = STRING: 0:15:5d:3:f:12
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.109 = STRING: 0:15:5d:0:78:0
IP-MIB::ipNetToMediaPhysAddress.1.10.10.3.111 = STRING: 0:15:5d:0:78:7
IP-MIB::ipNetToMediaPhysAddress.2.201.16.193.158 = STRING: b8:af:67:f7:8a:88
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.3 = IpAddress: 10.10.3.3
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.4 = IpAddress: 10.10.3.4
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.7 = IpAddress: 10.10.3.7
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.9 = IpAddress: 10.10.3.9
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.13 = IpAddress: 10.10.3.13
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.14 = IpAddress: 10.10.3.14
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.16 = IpAddress: 10.10.3.16
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.17 = IpAddress: 10.10.3.17
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.19 = IpAddress: 10.10.3.19
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.21 = IpAddress: 10.10.3.21
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.29 = IpAddress: 10.10.3.29
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.30 = IpAddress: 10.10.3.30
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.31 = IpAddress: 10.10.3.31
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.33 = IpAddress: 10.10.3.33
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.57 = IpAddress: 10.10.3.57
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.59 = IpAddress: 10.10.3.59
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.62 = IpAddress: 10.10.3.62
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.63 = IpAddress: 10.10.3.63
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.71 = IpAddress: 10.10.3.71
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.78 = IpAddress: 10.10.3.78
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.79 = IpAddress: 10.10.3.79
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.85 = IpAddress: 10.10.3.85
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.107 = IpAddress: 10.10.3.107
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.109 = IpAddress: 10.10.3.109
IP-MIB::ipNetToMediaNetAddress.1.10.10.3.111 = IpAddress: 10.10.3.111
IP-MIB::ipNetToMediaNetAddress.2.201.16.193.158 = IpAddress: 201.16.193.158
IP-MIB::ipNetToMediaType.1.10.10.3.3 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.4 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.7 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.9 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.13 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.14 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.16 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.17 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.19 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.21 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.29 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.30 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.31 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.33 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.57 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.59 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.62 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.63 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.71 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.78 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.79 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.85 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.107 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.109 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.1.10.10.3.111 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.2.201.16.193.158 = INTEGER: dynamic(3)
IP-MIB::ipRoutingDiscards.0 = Counter32: 0
IP-MIB::icmpInMsgs.0 = Counter32: 1391188
IP-MIB::icmpInErrors.0 = Counter32: 877570
IP-MIB::icmpInDestUnreachs.0 = Counter32: 53
IP-MIB::icmpInTimeExcds.0 = Counter32: 877699
IP-MIB::icmpInParmProbs.0 = Counter32: 0
IP-MIB::icmpInSrcQuenchs.0 = Counter32: 0
IP-MIB::icmpInRedirects.0 = Counter32: 0
IP-MIB::icmpInEchos.0 = Counter32: 70244
IP-MIB::icmpInEchoReps.0 = Counter32: 443192
IP-MIB::icmpInTimestamps.0 = Counter32: 0
IP-MIB::icmpInTimestampReps.0 = Counter32: 0
IP-MIB::icmpInAddrMasks.0 = Counter32: 0
IP-MIB::icmpInAddrMaskReps.0 = Counter32: 0
IP-MIB::icmpOutMsgs.0 = Counter32: 1274936
IP-MIB::icmpOutErrors.0 = Counter32: 0
IP-MIB::icmpOutDestUnreachs.0 = Counter32: 551368
IP-MIB::icmpOutTimeExcds.0 = Counter32: 11
IP-MIB::icmpOutParmProbs.0 = Counter32: 0
IP-MIB::icmpOutSrcQuenchs.0 = Counter32: 0
IP-MIB::icmpOutRedirects.0 = Counter32: 209984
IP-MIB::icmpOutEchos.0 = Counter32: 443329
IP-MIB::icmpOutEchoReps.0 = Counter32: 70244
IP-MIB::icmpOutTimestamps.0 = Counter32: 0
IP-MIB::icmpOutTimestampReps.0 = Counter32: 0
IP-MIB::icmpOutAddrMasks.0 = Counter32: 0
IP-MIB::icmpOutAddrMaskReps.0 = Counter32: 0
TCP-MIB::tcpConnState.0.0.0.0.53.0.0.0.0.0 = INTEGER: listen(2)
TCP-MIB::tcpConnState.0.0.0.0.1723.0.0.0.0.0 = INTEGER: listen(2)
TCP-MIB::tcpConnState.0.0.0.0.5000.0.0.0.0.0 = INTEGER: listen(2)
TCP-MIB::tcpConnState.127.0.0.1.2601.0.0.0.0.0 = INTEGER: listen(2)
TCP-MIB::tcpConnState.127.0.0.1.2604.0.0.0.0.0 = INTEGER: listen(2)
TCP-MIB::tcpConnState.127.0.0.1.9001.0.0.0.0.0 = INTEGER: listen(2)
TCP-MIB::tcpConnLocalAddress.0.0.0.0.53.0.0.0.0.0 = IpAddress: 0.0.0.0
TCP-MIB::tcpConnLocalAddress.0.0.0.0.1723.0.0.0.0.0 = IpAddress: 0.0.0.0
TCP-MIB::tcpConnLocalAddress.0.0.0.0.5000.0.0.0.0.0 = IpAddress: 0.0.0.0
TCP-MIB::tcpConnLocalAddress.127.0.0.1.2601.0.0.0.0.0 = IpAddress: 127.0.0.1
TCP-MIB::tcpConnLocalAddress.127.0.0.1.2604.0.0.0.0.0 = IpAddress: 127.0.0.1
TCP-MIB::tcpConnLocalAddress.127.0.0.1.9001.0.0.0.0.0 = IpAddress: 127.0.0.1
TCP-MIB::tcpConnLocalPort.0.0.0.0.53.0.0.0.0.0 = INTEGER: 53
TCP-MIB::tcpConnLocalPort.0.0.0.0.1723.0.0.0.0.0 = INTEGER: 1723
TCP-MIB::tcpConnLocalPort.0.0.0.0.5000.0.0.0.0.0 = INTEGER: 5000
TCP-MIB::tcpConnLocalPort.127.0.0.1.2601.0.0.0.0.0 = INTEGER: 2601
TCP-MIB::tcpConnLocalPort.127.0.0.1.2604.0.0.0.0.0 = INTEGER: 2604
TCP-MIB::tcpConnLocalPort.127.0.0.1.9001.0.0.0.0.0 = INTEGER: 9001
TCP-MIB::tcpConnRemAddress.0.0.0.0.53.0.0.0.0.0 = IpAddress: 0.0.0.0
TCP-MIB::tcpConnRemAddress.0.0.0.0.1723.0.0.0.0.0 = IpAddress: 0.0.0.0
TCP-MIB::tcpConnRemAddress.0.0.0.0.5000.0.0.0.0.0 = IpAddress: 0.0.0.0
TCP-MIB::tcpConnRemAddress.127.0.0.1.2601.0.0.0.0.0 = IpAddress: 0.0.0.0
TCP-MIB::tcpConnRemAddress.127.0.0.1.2604.0.0.0.0.0 = IpAddress: 0.0.0.0
TCP-MIB::tcpConnRemAddress.127.0.0.1.9001.0.0.0.0.0 = IpAddress: 0.0.0.0
TCP-MIB::tcpConnRemPort.0.0.0.0.53.0.0.0.0.0 = INTEGER: 0
TCP-MIB::tcpConnRemPort.0.0.0.0.1723.0.0.0.0.0 = INTEGER: 0
TCP-MIB::tcpConnRemPort.0.0.0.0.5000.0.0.0.0.0 = INTEGER: 0
TCP-MIB::tcpConnRemPort.127.0.0.1.2601.0.0.0.0.0 = INTEGER: 0
TCP-MIB::tcpConnRemPort.127.0.0.1.2604.0.0.0.0.0 = INTEGER: 0
TCP-MIB::tcpConnRemPort.127.0.0.1.9001.0.0.0.0.0 = INTEGER: 0
TCP-MIB::tcpInErrs.0 = Counter32: 0
TCP-MIB::tcpOutRsts.0 = Counter32: 3641
UDP-MIB::udpLocalAddress.0.0.0.0.514 = IpAddress: 0.0.0.0
UDP-MIB::udpLocalAddress.10.10.3.5.161 = IpAddress: 10.10.3.5
UDP-MIB::udpLocalAddress.10.10.3.5.500 = IpAddress: 10.10.3.5
UDP-MIB::udpLocalAddress.10.10.3.5.4500 = IpAddress: 10.10.3.5
UDP-MIB::udpLocalAddress.127.0.0.1.53 = IpAddress: 127.0.0.1
UDP-MIB::udpLocalAddress.127.0.0.1.500 = IpAddress: 127.0.0.1
UDP-MIB::udpLocalAddress.127.0.0.1.4500 = IpAddress: 127.0.0.1
UDP-MIB::udpLocalAddress.201.16.193.153.161 = IpAddress: 201.16.193.153
UDP-MIB::udpLocalAddress.201.16.193.153.500 = IpAddress: 201.16.193.153
UDP-MIB::udpLocalAddress.201.16.193.153.4500 = IpAddress: 201.16.193.153
UDP-MIB::udpLocalAddress.201.16.193.154.500 = IpAddress: 201.16.193.154
UDP-MIB::udpLocalAddress.201.16.193.154.4500 = IpAddress: 201.16.193.154
UDP-MIB::udpLocalAddress.201.16.193.155.500 = IpAddress: 201.16.193.155
UDP-MIB::udpLocalAddress.201.16.193.155.4500 = IpAddress: 201.16.193.155
UDP-MIB::udpLocalAddress.201.16.193.156.500 = IpAddress: 201.16.193.156
UDP-MIB::udpLocalAddress.201.16.193.156.4500 = IpAddress: 201.16.193.156
UDP-MIB::udpLocalAddress.201.16.193.157.500 = IpAddress: 201.16.193.157
UDP-MIB::udpLocalAddress.201.16.193.157.4500 = IpAddress: 201.16.193.157
UDP-MIB::udpLocalPort.0.0.0.0.514 = INTEGER: 514
UDP-MIB::udpLocalPort.10.10.3.5.161 = INTEGER: 161
UDP-MIB::udpLocalPort.10.10.3.5.500 = INTEGER: 500
UDP-MIB::udpLocalPort.10.10.3.5.4500 = INTEGER: 4500
UDP-MIB::udpLocalPort.127.0.0.1.53 = INTEGER: 53
UDP-MIB::udpLocalPort.127.0.0.1.500 = INTEGER: 500
UDP-MIB::udpLocalPort.127.0.0.1.4500 = INTEGER: 4500
UDP-MIB::udpLocalPort.201.16.193.153.161 = INTEGER: 161
UDP-MIB::udpLocalPort.201.16.193.153.500 = INTEGER: 500
UDP-MIB::udpLocalPort.201.16.193.153.4500 = INTEGER: 4500
UDP-MIB::udpLocalPort.201.16.193.154.500 = INTEGER: 500
UDP-MIB::udpLocalPort.201.16.193.154.4500 = INTEGER: 4500
UDP-MIB::udpLocalPort.201.16.193.155.500 = INTEGER: 500
UDP-MIB::udpLocalPort.201.16.193.155.4500 = INTEGER: 4500
UDP-MIB::udpLocalPort.201.16.193.156.500 = INTEGER: 500
UDP-MIB::udpLocalPort.201.16.193.156.4500 = INTEGER: 4500
UDP-MIB::udpLocalPort.201.16.193.157.500 = INTEGER: 500
UDP-MIB::udpLocalPort.201.16.193.157.4500 = INTEGER: 4500
SNMPv2-MIB::snmpInPkts.0 = Counter32: 36497
SNMPv2-MIB::snmpOutPkts.0 = Counter32: 21863
SNMPv2-MIB::snmpInBadVersions.0 = Counter32: 0
SNMPv2-MIB::snmpInBadCommunityNames.0 = Counter32: 14630
SNMPv2-MIB::snmpInBadCommunityUses.0 = Counter32: 0
SNMPv2-MIB::snmpInASNParseErrs.0 = Counter32: 4
SNMPv2-MIB::snmpInTooBigs.0 = Counter32: 0
SNMPv2-MIB::snmpInNoSuchNames.0 = Counter32: 0
SNMPv2-MIB::snmpInBadValues.0 = Counter32: 0
SNMPv2-MIB::snmpInReadOnlys.0 = Counter32: 0
SNMPv2-MIB::snmpInGenErrs.0 = Counter32: 0
SNMPv2-MIB::snmpInTotalReqVars.0 = Counter32: 133813
SNMPv2-MIB::snmpInTotalSetVars.0 = Counter32: 0
SNMPv2-MIB::snmpInGetRequests.0 = Counter32: 19931
SNMPv2-MIB::snmpInGetNexts.0 = Counter32: 1809
SNMPv2-MIB::snmpInSetRequests.0 = Counter32: 0
SNMPv2-MIB::snmpInGetResponses.0 = Counter32: 0
SNMPv2-MIB::snmpInTraps.0 = Counter32: 0
SNMPv2-MIB::snmpOutTooBigs.0 = Counter32: 0
SNMPv2-MIB::snmpOutNoSuchNames.0 = Counter32: 0
SNMPv2-MIB::snmpOutBadValues.0 = Counter32: 0
SNMPv2-MIB::snmpOutGenErrs.0 = Counter32: 0
SNMPv2-MIB::snmpOutGetRequests.0 = Counter32: 0
SNMPv2-MIB::snmpOutGetNexts.0 = Counter32: 0
SNMPv2-MIB::snmpOutSetRequests.0 = Counter32: 0
SNMPv2-MIB::snmpOutGetResponses.0 = Counter32: 21887
SNMPv2-MIB::snmpOutTraps.0 = Counter32: 0
SNMPv2-MIB::snmpEnableAuthenTraps.0 = INTEGER: disabled(2)
SNMPv2-MIB::snmpSilentDrops.0 = Counter32: 0
SNMPv2-MIB::snmpProxyDrops.0 = Counter32: 0
(tenho um template com as informações que deram certo https://share.zabbix.com)
For the benefit of the community, Google Translator used (Portuguese to English).
Happy to Help,
Marcus ![]()
@mldowling Thanks for the translation.
May i know the firmware version running for your B710 ? Start with firmware 6.3.0 and above, we have enhance the CPU and memory usage SNMP monitoring OID. Please use the Peplink MIBs to monitor the info:
OID: .1.3.6.1.4.1.23695.200.1.1.1.3
MIBs Download URL:
Sem sucesso…
