KPS
1
Hi!
I just made an update of one of my Peplink Balance ONEs.
The problem is, that the interface-numbers are not "stable:
Before upgrade: 4G-interface: 007
After upgrade: 4G-interface: 011
Before upgrade: First VPN - 008
After upgrade: First VPN - 009
→ My monitoring fails.
How can I achieve, that these definitions are “stable”?
Regards,
KPS
@KPS
Do you mean the interface number is changed ? May i know the firmware version before and after upgrade firmware ?
Beside that , wold you able to share the SNMP OID you are using ?
KPS
3
@sitloongs
It was an update from one 7.1.1 build to another.
I am using PRTG which checks:
- description:
1.3.6.1.2.1.2.2.1.2.INTERFACENUMBER
- status:
1.3.6.1.2.1.2.2.1.8.INTERFACENUMBER
etc.
Linux-default-mib.
@KPS
Would you able to confirm the firmware version that you upgraded ?
KPS
5
@sitloongs
It was 7.1.1s067-build3888 to 7.1.1s104 build 3995
TK_Liew
6
Please try our MIB. You should able to query with OIDs below:
@KPS
Don’t think this is related to the firmware upgrade as your device still running under firmware 7.1.1.
I may need more information from you in-order to confirm this.
Would you please share me the ifIndex & IfDescr for your device now ? That should give you the current interface mapping for the device now.
ifIndex - .1.3.6.1.2.1.2.2.1.1
ifDescr - .1.3.6.1.2.1.2.2.1.2
If you find the SNMP polling results can’t share here, please PM me the results and we can further discuss the results using private message (PM).
