SMS control settings via InControl
Does anybody know if there is a way to enable and configure SMS control on (for example) a MAX HD2 Mini via InControl?
For now this the only thing we manually configure in the HD2 itself.
Greetings,
Sam
You can use the bulk config tool to push those settings to a batch of devices I expect.
Hi Martin,
We have deployed many Peplink devices, and each uses a different configuration. We planned to enable SMS control on all these Peplink devices (they all will use the same numbers). Some of the device firmware is using at least version 8.3.0, the rest are on the latest firmware (8.5.3).
When using bulk config tools, how do I ensure the changes apply only to the SMS Control? Any advice you can share?
Thank you.
