Are there any plans currently to implement the ability to establish a VPN connection from a smartphone directly to a Max router, so that a middle device such or another gateway or SpeedFusion is not needed?
This is already supported via L2TP or PPTP. Thanks.
Thanks Tim! Is there documentation that can be referenced for setting this up?
You may refer to this kb article on the tutorial to setup L2TP over IPSEC.
@Oh_Yaw_Theng Thank you so much!
