Small Firewall Improvements
In the firewall rule for Port options you have:
  • Any Port
  • Single Port
  • Port Range
There should also be an option for:
  • Port List
So you can create a list of ports for one firewall rule. Similar to Group Networks.
It would cut down the need to create as many firewall rules this way and make the firewall rule list a little more easy to look at and manage.
Also how about adding an option under Protocol:
  • TCP/UDP
This is for rules where you want both protocols covered under one rule. Right now you have to create two rules which just further clutters up the firewall list.
These make sense. I filed the requests and relayed them to the team.
Thanks for your feature requests.
Thank you for listening. I appreciate it.
How about going one step further than “port list” and add something like “port group”.
Similar to how we have grouped networks we define a group of ports or services for use in the rule.
This would allow configuration elements to be reused more freely between rule sets.
