We want to use a PBL20 with on WAN1 a internet connection and WAN2 a FBB.
Then we connect a PC to the LAN port of the PBL20 and we want to run all traffic over WAN1 exept the Skyfile traffic, as this will only work on FBB…
Does someone know which IP or domain we need to use in the outbound policy?
How about enforcing all traffic from the machine running Skyfile to WAN three, the connecting to Skyfile. You can then go to “Active Sessions” and see all the sessions according from that machine. Make a note of them, enter them in your outbound policies and then disable the original rule of all traffic to WAN 3.
Thank You
Create outbound policies that direct all traffic to balance between your other WANs. Make sure this rule is below the rules relating to Skyfile.
Create inbound firewall rules to block all traffic on WAN 3 except the ports and protocols required. Make sure the block all rule is the last rule otheways Skyfile won’t work
No firewall rules required because the traffics will forwarded base on the defined outbound policy.
Regarding to the require domain name for mail.skyfile.com, i would suggest you should further analyze any other hidden domains that you are not aware for the sites or to be safe you can define the domain using skyfile.com instead of mail.skyfile.com.
Thanks for your message sitloongs!
It makes it more clear now
I have done what you said but still there is a small data uses of about 4 kbps every minute, any idea what this could be?
My thoughts were healthcheck so I disabled it but it still appears…
Can you share how you know there is 4Kbps usage every minute?
Please check active session for WAN3 at Status > Active Sessions > Search. Have you see any abnormal session (incorrect source IP, destination IP or port number)?
As you see here there is a constant data usage.
Also, on Friday the Peplink reported a usage of 8 MB on WAN3 but the airtime provider reported a usage of 38,7MB.
Before, without the Peplink, we used RAS dail-in to enable the FBB for a periode of time.
Will it be possible to create a situation that we use the FBB with RAS dial-in through the Peplink in any way?
Regarding to your requirement, we need more info regarding to the RAS dial-in ? Do you have the configuration setup on that so that we can understand further on the existing setup ?
The above setup is the old setup.
The one on the bottem is how I want the setup.
With the old setup, Skyfile starts a PPPoE dial-in session to the FBB IP 192.168.0.1.
Now I want to recreate this that Skyfile is allowed to start a PPPoE session to WAN3.
