Does anyone know if there is a limitation to how many SIP endpoints can be registered through a Peplink Balance 30? It seems like I can only get 20 endpoints to register at once.
SIP Registraion Limitation on Peplink Balance 30?
Jason
#2
Hello Karl,
I do apologize for the delay in getting back to you.
The Peplink Balance 30 does not have a limit on SIP endpoint registration. You should be able to register as much as need be. If you are having errors or issues with this, we would want you to capture a diagnostic report from the Balance while the issue is occurring and send that it to us for review on a support ticket.
Instructions on capturing the diagnostic report can be found at the following link-
You can turn in the report along with your support ticket at the following link-
http://www.peplink.com/contact/support/
Best Regards,
Jason
The Peplink Team
