I have a Balance One Core (with 5 WANs) and an older Balance 30 (3 WANs; no LTE). I now have more WANs than either can handle alone. Currently I have the 30 load-balancing two similar links and passing that to the One as single LAN. NAT, DHCP, etc. is set up on each device with unique local IP ranges.
I also have some Pepwave devices connected into Balance One WAN ports, set up similarly.
Is there a simpler way to set up this network so that most administration is more consolidated onto one of the routers, e.g., the Balance One, especially Outbound Policy, DHCP reservations, and Status (client list, sessions,bandwidth views)? I don’t want to use InControl.
