sim slot B not working - max br1 mini hw3
hi,
i just tried to use a secondary sim in slot B … but it is not detected … i even tried my working SIM from slot A in slot B without success… am I missing something or ist my slot B broken ?
  • it is enabled as shown in th attached screenshot
  • did a workaround and put the second SIM in another wireless router and integrated this channel via Wifi WAN
    but i still woul love to have two working SIMs in my peplink device
    cheerz from switzerland
just checked the event log: it at least says “SIM inserted in slot B” … but nothing more happens …
just found this on the manual of the router which states the following:
"The MAX BR1 Mini is a single modem device with 2 SIM slots. You can load two
SIMs and switch between them, but only one can be used at a time. "
question for me now is HOW to switch between A and B
Hi Gerold,
you can switch with the priority or if one has no signal, the router will try the other.
BR
Dennis
