Hi.
Is there an issue with the SIM Pool Report? I receive 400+ emails over the weekend for one of the groups I enabled it to. Other organizations/groups seems to be okay.
Josephine
SinglePoint Communications
Hi.
Josephine
I haven’t experienced this on our sim reports.
Suggest you navigate to the sim pool report and use the feedback tab on IC2 itself to ask the team direct. They’ll have all the info they need then to look into it for you.
