SIM pin management
Having issues with SIM pins.
If i enter a SIM into my BR1 8.3.0 build 5229 and i wanted to remove/disable the pin - where would i go to do so?
I have entered the SIM - and the corresponding pin. So far so good - the SIM is active etc. But if i wanted to disable the pin? Next to the boxes to type the pin - there is a ?. It says - if you want to manage the pin - click here. Opens a new window - but no options show up.
Was the same on the BR1 with 8.2.0 build 4961.
Sidenote is that i can nowhere type in a PUK code to reset the pin …
Is this known stuff?
