(1) Ports and connections
SIM Injector Mini can be powered via its 1x 802.3at PoE input 10/100M Ethernet port. It can also be powered via the Microfit connector.
SIM Injector supports 802.3at PoE output via its 4x 10/100/1000M Ethernet ports. It can be powered via the DC Jack or the terminal block.
(2) SIM Slots
- SIM Injector Mini supports 8x Nano-SIM cards (4FF).
- SIM Injector supports 8x Mini-SIM cards (2FF).
(3) Form Factor
- SIM Injector Mini is 3.9 x 4.2 x 1.4 inches / 100 x 107 x 35 mm.
- SIM Injector is 5.8 x 5 x 1.6 inches / 147 x 128 x 40 mm.
(4) Works best with
- SIM Injector Mini works best with PoE output devices such as EPX, SDX Pro, MBX, MBX Mini, etc.
- SIM Injector is perfect for applications that require HD Domes to be powered up via PoE.
