I want to ask about SIMcard injector. We know that SIM Injector can add 8 SIMcards, my question is, can we make bandwidth bonding using all those 8 SIMcards?
If it’s possible how the deployment method? can we use SIM Injector and any peplink as a router (for example MAX BR1 or UBR)?
You can bond as many SIM cards as the router can support (i.e. how many cellular modems the router has). The BR1 only supports a single active SIM card. If you want to bond multiple SIM cards at the same time, you will need to consider products such as the HD2 MBX (two active SIM cards), HD4 MBX (4 active SIM cards) or the EPX.
Also, please note that not all of our products support the SIM Injector.
the SIM-Injector is the SIM-Module. It is not a router or a cellular module.
If you use a HD2 you can bond 2 SIMs, but you can use 12 SIM-Cards (4 in the HD2, 8 in the Injector), so you can change the SIMs with software without a screwdriver.
