I have the the Max BR1 LTE, and the instructions are unclear on which way to insert the sim card. I dont know what orientation to use.
Also, I dont see any sort of eject button: how do I eject the sim card?
The SIM card can only be inserted one way and you will feel it click into place. To eject it you just need to push the SIM inward and you will feel it click out.
If you are inserting into the top SIM slot then the gold contacts should be pointing down with the notched side going in first.
Ah! There we go. Thanks!
