Short (5-6 feet) LMR-200 or LMR-195 SMA/SMA jumpers: Sources?
When I switch my buddy’s installation to the Poynting XPOL-2-5G antennas we’ll have a problem: With 15 feet of coax we’d be obliged to move the modem up to about 15-20 feet off the floor. Not a show-stopper, but not particularly convenient for access.
Plus: The higher we mount it on the wall, the warmer it’ll be in summertime. Semiconductors + heat = bad.
I think the little additional attenuation hit we’d take from adding 5-6 foot extensions wouldn’t hurt much. Problem is: I can’t find anybody that sells short LMR-200 or LMR-195 SMA Male/SMA Female extensions.
Anybody have any recommendations?
I’ve half a mind to try to buy the coax, myself, and the crimp-on connectors, buy the appropriate die set for my Paladin crimpers, and fabricate my own.
Have you checked out showmecables.com?
Is this what you are looking for:
https://www.showmecables.com/by-category/cables/wifi-microwave?connector2=2219&gender2=1780&cat=1367
Or they have beefier cables too.
I can’t vouch for them personally other than fast shipping, I have only ordered one cable from them and haven’t used it yet but have heard good things.
Thanks, @marcs, I’ll take a look… after I recover from this weekend’s trip to the site and back :slight_smile:
Yikes! $37 for a five-foot cable? I think we’ll just keep the 15-footers from our Peplink vendor, I’ll cut 'em to length, and re-terminate them myself–all for a fraction of the cost.
Thanks for the pointer, anyway!
I’ve done lots of coax cable termination over the years, between my CB radio, Ham radio, and 10base2 (coaxial Ethernet) days :slight_smile:
Turns out I even already own the correct die set for crimping the ferrules–from when I had to lop-off the connector for our boat’s GPS antenna coax to route it through a cable gland on the transom, and re-terminate it.
mpd digital makes custom size cables
i think they solder too, you dont just want to crimp
Thanks! I’ll look into them.
That’s what I once thought. Then I found out properly-executed crimps are regarded by many to be mechanically superior to soldering–particularly in applications with environmental and mechanical extremes. Found that out when I looked into an extensive boat rewiring project.
