HI we see traffic with source IP 5.192.x.y onto the LAN from one of our Balance series and I suspect it could be that the source address is assigned to a SFVPN tunnel endpoint. Has anyone else seen such addresses and can you shed any light on what is its, why it might be leaking onto the LAN side?
An issue was discovered when port forwarding to servers located at remote PepVPN sites. The source IP gets incorrectly translated to the PepVPN virtual IP address when going through SpeedFusion and this will be corrected in 6.3.2 firmware.
