Dear support, do you have a compatibility list of dongle usb-c/ethernet adapter ?
thanks
Antonio
@asimula, I do not quite understand your question, can you explain more what you trying to achieve?
BTW, do you think this post would help?
Hi WeiMing, i want know if the usb-c\ethernet adapter is support on SFE ? if yes, do you have a list of the adapter compatibility with SFE .
In the post of Sitloongs, he use a cable usb-c\usb .
thanks
Antonio
