I have a situation where an outage on a WAN causes the fusion connection to drop the use of that wan - SFC continues to work from the other WAN (but no longer uses both bonded).
Navigating into the WAN (from dashboard), un-checking enabled, clicking save/apply, then re-enabling cycles the WAN (which SFC was not using) and SFC connection then resumes using it/both.
1 - WANS working
SFC reports WAN not working / not in use
Wan disabled/re-enabled
SFC now shows WAN in use
Both WANs are connected via ethernet ports.
|Firmware|8.5.0 build 5496|
|SpeedFusion VPN Version|9.2.2|
