Setup SFC Connect Yesterday and I am trying to determine if its working
SOLVED I look in the status tab and only see this. Which makes me think nothing is bonding and going thru SFC. Status -Bill I hadn’t used the wizard and did it incorrectly. I tried the wizard and its all working as expected now.
I am unable to retrieve the image you referenced. However, I’m wondering if (1) you set multiple WANS to be bonded and those WANs are active, and (2) if you used Outbound Policy to direct traffic to that tunnel?
Turns out I hadn’t set it up correctly. I deleted what I did and used the SFC Wizard and its all working now.
I’d like to add that a useful tool for troubleshooting is going to active sessions to see where traffic is being actively sent.
