Hi all, can anyone help me
I had an old Peplink Loadbalance 710 (connect to a switch to connect 4 WAN). Now i buy a new Peplink Loadbalance 710 will connect to that switch and connect more 3 WAN, I want to config HA between my new Peplink Loadbalance to my old Peplink Loadbalance. What’s step i should do now???
Thanks all
Can anyone help me???
please have a look at this post
Best wishes
Dennis
Thank you, but i want to know propoties step because i had an old Peplink and now i just a new Peplink.
It’s generally recommended that the hardware versions of both routers be the SAME. Is that the case in your situation? If so, then the instructions are here.
Edit: Sorry, @toannguyen290497. Looks like you have two threads going here …
