I use IC2 to manage my Pepwave MAx Transit but I’m not sure how to navigate joining a local WIFI network that is listed as open so there is no place to add a password but there is a password required. It is supposed to be added to a splash page that you get when you try and go online.
On secure networks it is easy because there is a spot for the password.
My issue is my Pepwave does not have a keyboard or monitor so any splash page never shows on the Pepwave. Any suggestions would be appreciated.
Thanks, got it to work but one question, I could only click on the public WAN network once it connected with Pepwave so it was too late to change the Health Check and before it connected I was not able to get to the Network option on the Pepwave system. Can you make this change via IC2?
You can use Remote Web admin from IC2. But I can’t see how that would work from IC2, because you need a internet connection to change any settings on a router with IC2. You need to log on to the router locally to change the health check settings on the WAN if you do not have a working internet connection.
Disabling the health check settings is only needed during the authentication process.
When you are successfully logged on and connected, the health-check can be re-enabled to monitor your WAN connection.
