Looking for some help getting a polycom realpresense windows client to make a receive video conference calls behind a Pepwave MAX HD4 MBX.
The requirements to make this soft client send and receive calls are these open ports:
TCP 1720
TCP 3230:3250
UDP 1719
UDP 3230:3285
I have set this up on a simple network and put these port forwards in place and had success.
However, with these same rules on my Pepwave MAX HD4 MBX I cannot get calls to function properly.
My setup:
Pepwave MAX HD4 MBX
Using Wifi and 4 sims for outbound connection to a Speedfusion VPN connecting to a Fusionhub hosted at AWS.
I have 4 services setup in the Advanced/Port Forwarding section of my router matching the rules specified above.
I also those same for services setup in port forwarding on the fusionhub at AWS.
Where have I gone wrong?
Thanks!
